ABS Light ?
Front End Pinion Seal?
Light out warning bell
I am trying to figure out my abs light issue
I tested the rear speed sensor on the rear axle
there is no resistace (it is open)
is it supposed to open
thanks guys
Dennis
05 FSM said:
9. REAR WHEEL SPEED SENSOR
Turn the ignition off. Connect the Rear Wheel Speed Sensor harness connector.
Measure the resistance between the Rear Wheel Speed Sensor (+) circuit and Rear Wheel Speed Sensor (-) circuit at the Controller Anti-lock Brake harness connector.
NOTE: The resistance should be approximately 1600-2300 ohms at 76 degrees F.
Is the resistance within the noted range?
Yes >> Go to 10
No >> Replace the Rear Wheel Speed Sensor in accordance with the Service Information.
I just disconnected the sensor connector at the diff and checked its resistance there. My speedo behavior never changed (that I noticed) with the bad rear sensor.
Thanks guys
I guess I need to replace sensor
the thing I don't get is, my speedometer works just fine?
Dennis
