I bet the booster is bad. Tap in a guage and see what happens when you step on it. Without the engine running, it should go down a little and stop. If the diaphragm is bad, the vacuum will go to 0. Could try it running too. Should be the same results, but the pump might keep a little vacuum on it.
Yep, its the booster... had 26" of vacuum with it at idle, stepped on brake pedal and down to 5" or so. Think I'll just get the loaded booster with a new MC while I'm at it, pretty sure thats still the original also.
