Now we'll discuss those values that were posted above there.
OEM THERMISTOR VALUES:
What you may have is a problematic controller or fault - elsewhere in the HVAC control system. I recommend opening up the controller (I can provide pictures of the gross-workmanship / quality issues) and inspecting it along with the smaller wire harness feeding the controller and the harness at the HAA / HAD that ties into the Thermistor Harness ASSY.
I have all the harnesses out so, at any time you need to physically see how the interconnects mate up - I can help provide images and detailed call outs if needed. Although, it may take me a bit as, I'm running another project concurrent so, I may not be able to immediately generate the necessary documentation on the fly.
CM
- R100 VALUE: 58 OHM @ 100C.
- R25 VALUE: 5K OHM @ 25C. This is its prime parameter measured at 1-ATM @ AMB / 25C. This can be called T1.
- R0 VALUE: *~16K OHM @ 0C. *NOTE: For sake of argument: ice water undisturbed, assumed temp at ~0C.
- R-22 VALUE: 58K OHM @ -22C
CM
