AC Evaporator - Need a new one. Where to find?
Tow hooks?
2WD to 4WD First Gen Conversion info ?
RSchwarzli
So what seemed so simple as usual got very complicated. :rolleyes:
My AC Evaporator decided to get a hole and blow smoke out the vents. I ordered replacement parts from RockAuto and got them. Ripped apart truck, got the parts out, found hole in old one, went to put in new one and this is what I found:
/webdata/photopost/data/500/medium/DSC_3616.JPG#ad
/webdata/photopost/data/500/medium/DSC_3617.JPG#ad
/webdata/photopost/data/500/medium/DSC_3618.JPG#ad
Seems the replacement ones are not bent at the same 30ish deg to allow for the angle of the heater box.
So I ordered another evap from another place. It arrived. Same thing! :{
Anyone know of a place you can get a correctly formed one? I cant bend the existing ones as the pipe is too thick and the small feeder pipes start to bend. If they crack, I am back to square one. Light headedness while driving! :-laf
Thanks!
I ordered one for a '92 from Oriely's for my '85 swap, and it was a smashed up POS!! I don't know how many places it had been shipped, or what engine blocks had been rolled over it while in the box, but it was no better than what I had. So I showed them, they "accidentally" gashed the hell out of it(BIG swing for a small guy!!), and it was sent back as defective. It didn't have the angle to it, I noticed at the time, comparing it to the old one, but the next one did... ... Both were Murray#54108, and the second one fit perfectly. The old one was corroded and stopped up from 10yrs of West Texas dust, but it might still be good, I didn't care to check it. I don't know why one was angled and the other wasn't. Boxed wrong?!?! You might call Rock Auto and see what they think... ... and certianly ask about the 54107 as PayChk suggested..... my $. 02...
I agree with DVolk above. I recently did exactly that. I drove my truck in to the local radiator shop, a local small business that has been in business at their location for 40 or 50 years, left the truck, and went away. A couple hours later they called and I returned to pick up the truck. Bill was about $200.
My OEM condensor was damaged by not one but THREE dummies at local small, private detail shops.
The first and second detailers used commercial grade pressure washers to destroy the fins on my evaporator.
The third dummy was me for trusting those morons to detail my truck.
Is this for the 90 or 93?
if you go to the 4 seasons catalog you can see the different evaps:
[2011 Illustrated Guide] - Powered by PageTurnPro.com
start at page # 221 (online page #) catalog number 210 and you can see the pictures of the cores.
I guess that would help! The 1990.
Yes, the four seasons part is wrong. I tried to order one of the two bent ones that would work and it is no longer available!
Yeah. Both that I have now seen have been beat to *%#@. I would say they have been sent back many times for being wrong.
54107 is 1. 5" shorter in length... . I tried that too. :{
go to a local radaitor shop
Yup. Last option. Going there this afternoon.
$ 200. 00 is cheap considering the freon if you used R12 is about $50. 00 a pound
My dad was in the automotive AC for over 30 years
Went to rad shop. They said not fixable. Time to get a new one. They pulled out their catalog of exacly the same thing as the other places! The Four Seasons catalog... .
Grrr. :(
You want me to try to get one through Oriely's? You can order it online, for around $130, but it looks straight, just like the one you don't want... ... Hmmmmm
That's the issue. It looks wrong already and as it is the same part number as what I originally got... ... hmmm
I do very much appreciate the offer though! :) that is very generous of you!
I have a lead on one that might be correct. Different brand. Will call tomorrow and see what I can find.
Can't brlieve this is so difficult. Has nomone else encountered this? There are enough 81-93 trucks still on the road... .
Did that after the first time I got the wrong part. When I went to order the second one from a local store, I went with dodge pn in hand. That matches the wrong one. The 54108. :(
105408 Spectra Premium. That's the discontinued one that looks right that I am tracking down. Will know this morning if I found one or not.
I replaced the one in my 93 in Nov. of 09. Oreillys' part number was 909314 with a price back then of 100 bucks. Don't know if this helps you or not, but it fit perfect in mine. However the heater core I got from them had to have a little modification to work.
OK. Update time!
I have the truck back together after two weeks of playing around trying to find parts. After 5 cores I managed to get a 95% correct one from NAPA. Part #A9395.
For those looking at doing theirs, it is not hard, just time consuming. It took about 10 hours to pull everything out and reassemble.
Thanks again for all the help guys!
Robert
Also for those looking for a new heater core to put in while they have the box out, it is Spectra Premium part # 94619. It is a little thicker than the stock one, and it is aluminum and not copper, but it is all that is available. :(
