Does anyone know where the accessory relay is located on these trucks? This is the relay that cuts electrical power to the fan blower and power windows while the starter motor is cranking. I began having an intermittant problem. After engine start, the power windows and A/C would not work. If I shut the engine down and re started, the problem would go away. Eventually. this relay stuck open, (the hottest day of summer of course) and I would be unable to open my windows or use my A/C. I have since jury rigged this with a relay mounted on my inner fender well powering these two circuits. I would like to eventually fix it correctly.
89 D-250 K&N, Boost/Pyro. & 16cm2 215K and still going. 91 W-250 16cm2, 6" Skyjacker lift, RS9000, Dump bed, 18K original mi.
