Addco or Hellwig sway bars???????
Where have all the dodges gone ?
Need Dodge 2008 4500 7-pin wire color schema guide
I'm looking at adding a REAR sway bar to my 2WD 2500, I've priced both the Hellwig and the Addco bar and want to see if anyone has installed one on the rear???
I've looked for a factory one but haven't had any luck.....
Which one is the better part? The Addco is 1" and the Hellwig is 1 1/8"
Thanks!
They are not hard to put on. JCWhitney has some good A-S-B the price is from 189. 99 to 399. 99 They also have Hellwig 129. 99 to 259. 99
Hellwig Sway Bars on an 06 Megacab
I installed Hellwig bars on my 06 Megacab dually. I initially had problems positioning my mounting brackets for the links on the frame due to having some interference issues with the brackets on my underbed mount Pullrite 5th wheel hitch. I called Hellwig and described the issue to one of their engineers and e-mailed him some pictures. Within a few days a package arrived with some custom fabricated mounts that fit properly at no charge. I find the Hellwig product to be of good quality. I find Hellwig as a company to be accessible and responsive to customer input, thus offering superior customer support. I often drive mountain roads and find that the product performs a it should and that it made a noticible difference on my vehicle. I highly recommend the Hellwig product.
I installed a Helwig anti-sway bar on my '03 3500 DRW 2-wheel drive truck several years ago. It took about an hour to install and no drilling required. I haul a heavy slide-in truck camper which is a high center of gravity load. The Helwig anti-sway bar helped with the sway both with the truck loaded and empty. To date, I've had no problems with it.
Bill
Great info... . and first-hand experience as well!!!
I'll probably end up with the Hellwig bar. I priced it on Summit Racing's website and it shows it for $240ish... ... Plus, the Hellwig bar is 1/8" bigger,
so that's the one for me!! :-laf
Thanks for all the input.
Well I ordered a Hellwig from Summit Racing to the tune of $229 but won't be shipped until September 6th... oh well that's soon enough for me!
