HHhuntitall
Lack of Sleep, I'm sure, HH!
A head shot(classic between the eyes) on a charging bear is risky!
That low sloping and very THICK skull can skin a slug off into the wild blue yonder with absolutely no effect on the bear other than to Pi** it off further. Solidifying in its mind that you are gonna be a steaming pile of "bear sign" on a forest trail, after he gets his revenge!
Shots fired down the throat, through the nose, the eye socket are all vulnerable shots if they are on all 4's charging you. However, you absolutely must retain a "stiff upper lip" whilst delivering that precision shot. Frankly speaking, unless you are accustomed to seeing Bear, a close up, high adrenaline encounter will probably be less accurate that you would desire! That's why fast, follow-up capability, is an absolutely necessity.
The real important thing is to be familiar with the anatomy of the critter you expect to encounter. Oh! And carry a change of Skivvies:-laf! GregH
Yes, GHarm, but when looking at the bear diagram, if you are aiming at a bear charging directly at you, the skull is the first point of aim. Most likely you will over shoot, and hit the spine. Off to each side, and you take a shoulder or lungs... ... or so I'm told. The low to the ground charge is what makes them vulnerable to the large, penetrating round... . I can't say that I know, only what I was told. Am I wrong there? A side shot isn't possible in a full blown direct charge, and we both know the quickest stop is skull or spine, which are lined up directly with you in a charge.
I do know what it's like to be charged, by various game and animals... . A skull shot on a 3,000lb bull is no problem!! Draw an X between the eyes and horns, and squeeze on center. Hogs might be similar to bears... . they charge and the best shot you're offered is the top of the head and spine area... although smaller hogs may charge sideways, trying to make themselves look larger than what they are... funny little gait... easy shot. The pop their teeth like bears when agitated.
Try the Nosler 300 Gr. Partitions, also! They are kinda expensive, but a quality game bullet. GregH
Definitely. The partitions will deliver the mail!! I use them quite a bit in 6. 5 and . 284.
