Aeromotive fuel pressure regulator questions
Haisley Machine Exhaust Manifold
Total adjustable boost.... How?
I am looking at the Aeromotive 13301 regulator and wonder if anyone else is using it and what the opinions are on adjustable regulators?
Thanks,
Dave
I have an aeromotive on mine. I don't think that is the one I am using. I like it. I have a gage and can dial the pressure right it. I figured $130 for a regulator versus the scheid Overflow valve at $60 some. I took the regulator. Hope this helps.
what kind of base pressure do you guys run in a 12 valve application? do you have it hooked up so that it increases pressure when referencing boost?
Thanks for the replies,
Dave.
I don't have a P-pump, but I do use the rising pressure feature. For me it rises a little more than 1:1, but works great.
Dave.
No reason to run over about 35 all the time. Don't run the 1 to 1 feature all the time, it will washout the pumps case inside over time.
Jim
air pressure regulator in line between the boost reference and the fuel pressure regulator. You can set the base line then have it rise with boost(1:1) till it hits the limit of the air regulator
This is how I have mine set up. Little VE doesn't need to see 60+psi of fuel pressure. Can't go wrong with Aeromotive products.
Does anybody know how to get ahold of these guys? I have emailed four times and left multiple messages over the last month and still no response from anyone at Aeromotive :confused: I am trying to get the 20-60psi spring and a replacement diaphragm for a 13301 regulator. Is there another vendor for Aeromotive products, besides Aeromotive, that i can get replacement parts?
Thanks, Dave
