Ahhhh..Does That Ever Feel Good...
Happy Birthday, MDW!
OOps I did it again ......
Three things come to my mind 1-passed gas(fart):eek: 2-took a leak:) 3-sort of related to the other two-took a dump:cool:
4-drove that jetta tdi that you talked about but did not buy it cause-:-{} 5-with your reputation of what you come up with who knows So are you going to tell us? Or are you just sticking a stick in the fire ant hole and stirring um up?
OK - OK
More than a year ago, my father-in-law re-did my utility room while I was laid up. In May, I began to repay his deed, when I removed the heads from his class C 79 Dodge motorhome, to be reconditioned.
The heads turned out to be junk, with cracks between the valves. We ran into trouble locating heads because the engine is a fairly rare HO 360 and none of the junk yards around here had a match. After almost three months of false starts, we came up with the correct heads, although one of them was bad too. Fortunatly the machine shop had one on the shelf.
I went out to the in-laws yesterday and installed the rebuilt heads. The engine started up and ran perfectly on the first crank.
Boy does it feel good when a job comes together like that :D
:D:D
You guys better go wash your minds out with soap!
Doc :D
