OK... this is getting old. Ive replaced the sealing washers on the pump banjo fittings, I replaced the overflow valve with the new/improved version... and the motor misses so badly that I can feel it shaking when running down the road at constant speed!! Could this be my lift pump? It really only sounds like one cylinder... Ive cleaned and inspected the injectors... . do delivery valves go bad? This all started after installing 370's... I put the 215s back in, Ive changed fuel plates... Im stumped. I am still getting over 22mpg with a crappy running engine, however!
