Air Compressor
Recalibrate sender/trip computer with replacement fuel tank?
Towing Mirrors
dualspt
Someone steer me to a portable air compressor where I can set the desired presure & it shuts off
when it reaches it. Not terribly high $$ pls.
Aw Heck if I could only Move this post to....
What Presure ya lookin' to shut down to? Any tools going to be run off of it? I can help ya out with a ton of starting points but The basics need to be seen. :) I now have a Hadley comp (150)psi with aprox 15 gallons of storage (Aux tank on its way) anyhow different scenerios need different compressors.
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Powerpacked (4 inch exhaust,High ram intake,wastgate mod to 38 psi,otto +guages,K&N) , Jakit's Front End Leveling Kit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Goodies, WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. Diesel Transmission Technology's ~93%TC~&~VB , TC Saver, Mag-Hytec'sDouble Deep Trans pan, DD1's + Van Aken + Full Autometer Guages. Play hard and live #ad
DOH!!!!!
Forgot one thing! There is an ADJUSTABLE Shut off regulator on the market I have seen before (5 ---> 150) PSI but I don't remember who on this green and blue ball makes it. :confused: :confused:
If I could Moderate this post would do well in... ... Products/Accessories ;) :D ;)
Just wondering why you want an adjustable shut off regulator?
In most cases you can install a simple (cheap) pressure regulator on the receiver outlet and set it to what ever pressure you want. Most air tools are designed to operate on 90 psi air. To overcome the losses as the air flows through the couplings and air hose you will need to set the regulator around 95 psi. If you have filters in line, then the regulator will need to be set even higher. If you use a presure switch to control pressure to tools, paint guns, etc. the pressure can swing up to 30 psi. It is usually better with a recipricating compressor to make and store air at say 175 psi and then very consistantly regulate it to the pressure you need. If I missunderstood what you are looking for, I appologise.
Gene
