Originally posted by RPainter
already searched the forums but none fit my problem The air conditioner keeps cycling about every minute or so. It is not turned on. Thought it was the fuel heater kicking in. Is my ac going bad or is there a sensor or switch I can replace myself.
Randy
the defrost is off. When I had it in the shop last week, had them check the a/c. 1 lbs low so had it recharged. still cycles about every minute and a half. Thinking this would burn it up at this rate. Have 99500 on it too. Would the fan clutch have anything to do with this? unplug the connector to the clutch coil on the compressor. See what happens. The only thing that would cause it to stay on would be the switch or a bad relay.
Randy
unplug the clutch coil connector on the compressor and see what happens.Originally posted by jungledave
And Yes it won't last forever.
