Seems there are as many opinions on this as there are on oil... . I don't like the idea of an oiled filter so what are my options? Cold air kits, cutting holes in the air box, bhaf... what's best? Thanks.
Boondocker said:What do want - more noise, more hot air, good filtration?
cone style in box - $250-300: more noise, about the same air temp as stock if air is drawn outside of the engine compartment, mostly oiled types.
BHAF with Outwears and heat shield - $100-150: slightly more more noise than stock, hotter air
Stock - $15: for a replacement filter, least noise, coolest air except for Scotty's, flows enough air to support 350-400 HP.
I ran a shielded, covered, BHAF for a couple of years. I just put my stock air box back on and notice 40-50 degree cooler EGT. With my current fueling mods, I haven't been able to pull the filter minder down, so the flow is sufficient.
AWray said:Check the seal around your filterminder. Mine never moved in the first 2. 5 years I owned the truck and most of the time it had the mods in my signature. The last time I cleaned my aFe, I pulled the filterminder and put some petroleum jelly on the inside and outside of the rubber grommet. Now I can pull 7" of vacuum.
Bajabob said:Checking to see if signature is coming through. I've got it checked off. Where's a computer geek when you need one?
Bajabob said:When I preview the post it shows signature. When I post it's a no-show.
Boondocker said:I switched back to the stock air box a couple of weeks ago. It was kind of an experiment, so I didn't bother with sig. The first week with the stock box, I was running a dirty old filter, didn't bother to get a new one when I switched to the BHAF. With the dirty filter, I was able to get the filter minder to move a bit with couple of hard up-hill runs empty. Now that I have a new filter in, the same test doesn't move the filter minder. I always lightly coat the rubber edge of the filter with petroleum jelly before installing in the box.
Neil
THenningsen said:do they have a BHAF, or is just the stock replacement?
