Originally posted by Bob Stephens
The only downside of the McCall is that you have to create a custom mounting bracket and that means welding to the frame. My hitch installer is reluctant to mount my McCall into an '03 so I'm either sticking with the '01 or moving to (God Forbid) a Pherd 450.
Bob,
If you take a copy of the
TSB to your installer, he may change his mind: welding
IS permitted on the '03 frames.
According to the TSB:
"WELDING:
Prior to welding, the following must he done.
1. Avoid welding near,the fuel tank, fuel and brake lines or other components that may be damaged by the heat of welding, If R is necessary to remove the fuel tank, lines or other components, do it In accordance with applicable service manual procedure.
2. Components near the welding area which could be damaged by excessive heat must be removed or adequately shielded.
3. Disconnect the battery(ies)
4. Precautionary measures should be used to prevent electrical system components or wiring damage.
5. Frame E-coating must be removed from the weld area prior to welding. Use proper welding techniques to avoid stress risers that may adversely affect frame performance.
AFTER WELDING:
1. Carefully inspect electrical components and wiring for shorts or other damage.
2. Apply an anti corrosion protective coating to the areas where the coating was removed. "
As you can see, there's no barrier to welding on an appropriate mount for your hitch!
