With my 3:73 ( I wanted 4:10's) at 65 MPH in 6th, I'm lower than I want, with RPM's around 1400/1500 RPM's, and as I start a climb I can feel the pressure building. As I have always complained about with the 3:42 diff, your RPMs would be around 1200/1300 RPM's, thats way to low for the CTD. 18-2100 RPM's is the sweet spot for the CTD. The 2014 2500 68rfe with 3:42 and 10K GVW drove me nuts, I never realy found a good strategy in how to run it, to keep the RPM's were they should be and not were FCA wanted it at for EPA and whatever reason they came up with. I think they saw a lot of potential buyers waiting for better gearing, like I did. I WOULD NOT HAVE CONCIDERED MY NEW 3500 SRW IF, I HAD TO GO WITH THE 3:42 DIFF. T/H is very aggressive with EB and RPM's, I'm still looking for the right combination, but city driving, I lock out 5th and 6th and run T/H. I can see why I got a lot of Run T/H all the time with the 68rfe, but that trans is not the same as the Aisin. Hunting for gears is normal, as your service writer is explaining to you with your setup, and there's no Codes/CEL's because its running as designed. Your now seeing what I was talking about in the 2015, when I was in the 2500 68rfe back then. I got drowned out by Aisin owners that had the 3500 SRW, but the Aisin has a different strategy than the 68rfe, and the RPM's are still low for 65 MPH and 3:42 and 5th or 6th gear.
