Cruise Control Anomaly - Just Started Today
Lower Radiator hose support spring
Advice on how to help my dad sell his 1998
Driving around 45 with cruise set. Maintains speed on level and slight incline in roadway. When on a decline the speed drops a little but then continues to drop and the cruise doesn't pick up on it. If I hit resume it goes back to setting? Don't drive the truck but once a week nowadays but last week it was fine.
History:
●10 maybe 15 years back the cruise light on dash would come on but not hold speed when set button pressed. Ended up needing new control module that's under left battery.
●around 5 or so years back was like module went bad. Turned out being a deteriorated vacuum hose. Replaced and all has been well until today.
When I got home I gave a cursory look at the vacuum lines at the cowel area and as far as I could easily see from cowel to under battery. The seem good.
Any help appreciated. Obviously not urgent but I use cruise all the time and want to resolve.
First thing I would do is cut off about 1/4 inch at each end of the ~1/8 inch or 5/16 inch vacuum hoses and plug them back on. You might have a microleak due to deterioration.
Thanks Matt. If/when I get a day above freezing I hope to take a look at the vacuum lines.
