Obviously a KOOOOK must have won the bid on the 2015 manuals. :-lafIneresting......here is the page from the 2016 diesel supplement.......just as the 2014 book says...... fluid every 30,000 and filter every 60,000.
Sam
Sam
Is the 68RFE service a partial fluid change???So from that I would expect they wan the FLUID CHANGED not just part of it
I see no where that it mentions a "FLUSH" or "EXCHANGE" or "100% fluid swap" for the transmission fluid ANYWHERE for the 68RFE or AS69RC.I see no where that it mentions partial fluid change ANYWHERE for 68RFE of Aisin.
Where did this partial change come from? Documentation?
Where does the "FLUSH" or "EXCHANGE" or "100% fluid swap" come from?
Does anyone have an FSM? I intend to buy one soon.....but.... it should have the procedure in it.
I think I mentioned it before...on all of the previous transmissions, transmission "service" consists of removing/draining pan, change filter, adjust bands and refill. In fact I know they would recommend against a flush unless the transmission had been flushed at all previous services since new.
How about you show me where it says to chance running the trans dry pumping fluid out through a removed line. If the factory intended other than just dropping the pan they would have made a provision for draining the cooler and converter.I think it's pretty darn clear what I am doing. Now someone please SHOW me where it says to partially change the fluid.
Everything that is shown says to change the fluid. Don't see how a partial change can be claimed as proper procedure when it does not say so. So please show me!
I'm not disagreeing with you. I don't think anyone on here would disagree that the more fluid that is changed is indeed for the better.I think it's pretty darn clear what I am doing. Now someone please SHOW me where it says to partially change the fluid.
I really don't care but I get jumped all over for saying that "I" will change all the fluid and filter because that's how I want to do it.
