CorrectThe 2500 doesn't have the Aisin, right?
From what I read, it is the 3500, Aisin, and the 3:42 gears that work well.
2015 3500 SRW 4x4 MegaCab Laramie Aisin
I never liked the 3:42 before and after the scramble. It's puts the CTD below its optimum RPM for power and torque. Everyone likes the 3:42, and that's OK, BUT I'LL NEVER BUY ONE WITH 3:42.
I would trust the Aisin more with 3:42 gears, but 4:10's in a 6spd auto is pretty nice, in that it allows you to drop your RPM's into the sweet spot for a Cummins. Unlike the 48re that would have you screaming up a grade. I wonder what the temperature difference is with the 3:42 vrs the 3:73 vrs the 4:10, in the rear differential. I had to install my own transmission cooler in my G56 because it runs hot @ 250*+ if I don't.
C12V98; A friend gave me a tip which I thot was worth passin' on:
He says every time he sprays off his rig, he sprays the fins on his Mag-Hytec to keep'em clean from road crap and thus keep'em cooler.. maybe ??
Wondering if letting a slowly leaking rear axle seal go will contribute to this. Is checking the fluid every 15,000 miles enough?
I wouldn't do that. Leakage is an indication of seal failure. Weepage on the other hand may be acceptable, but warrants close watching. The pinion seal has weeped on several of my trucks, but it doesn't form a drip, so I monitor it but for the most part ignore it.
2014 2500 with 3:42 scrambled at 14K miles, and thats not on my computer, thats on Dodges computors. Also Dodge had to buy back the truck for other unrelated issues, So I can speak from experiance. My next CTD will have the 4:10's.
I have a 3500 for capability, not MPG.Why was I able to tow 28-29K combined West Coast with my measly 350/800 HO Dually with 3.42's??? Because in reality it was a 4.10 in 5th.
New 385/900 with AISIN and 3.42's is a serious towing machine per RAM up to 28-29K range.
If my RV was 5K lighter I would be running 3.42's for sure. Also I would be getting 14-15 running around instead of 12-13mpg.
Just convince someone else the 3:42 is OK. You can post all the positive info you want, and it won't convince me. If the capability with 3:42 is 30K, then with 4:10 its 35K. I wont be buying a truck soon anyway so its a mute point. I don't care why my 3:42 failed, just know it did, and the whole housing, and related parts had to be rebuilt. I don't understand why they rebuilt it vrs replace the assembly, but IT DID FAIL. This will be my last post on this subject.
