It didn't have the traditional OBD-II port, it had that funky looking port with the German name that I can't seem to recall at the moment. :-laf
What, a Deutsch (pr. Doytch) conector maybe?
Yup - I'm pretty sure that's the one.
Round... 5 or 6 pins, IIRC.
It's "Deutsch" - just found the spelling online...
Matt
As a former owner of a DTT modified 47RH and current owner of a bone-stock LCT-1000, I won't be going back to a 47RH/RE. The Allison was designed with a clean sheet to take abuse, the Chrysler trannies were slowly upgraded over time to maybe just barely make it to the end of the warranty period with a gentle right foot and OEM engine.
Matt
Anyone that was on DTR reading the thread about the allison transmission swap, you will need to come here for the factual info now. Brayden and I (GMac) got kicked off of DTR because of Opie running his mouth on stuff he doesn't know on DTR. So come here for info.
The top of the line ATS Allison 1000 is roughly $8,120, which includes their version of the PCS TCU minus shipping or installation with a core charge of over $2,100. So i guess actual costs would exceed $10,000 for those of us who require the ultimate in durability, especially after factoring in the costs of a conversion kit. One can have a top of the line Chrysler or Ford transmission for far less. How many miles would it take to recoup fuel savings from the swap?
If anyone has had success in programming an Allison that has been swapped into a Dodge or Ford having no issues with over 600 hp to the ground, my buddy would be interested in knowing about it for his truck. User programmable being ideal but with what software and hardware?
When i had my Allison on the workbench it sure seemed big. I'm surprised that ground clearance is is the same, especially with the drop shape of the housing around the torque converter. Good to know. I may someday have money to play with and consider the Allison again.
Even if shifting an automatic manually, no clutch is required and you still get the benefit of torque multiplication from the torque converter, two features unavailable in a manual transmission. The way the aftermarket has come to the aid of automatic transmissions in the past several years has made them more durable under extreme usage like sled pulling and street racing than manual transmissions.
