Long time listener, First time caller.
(Some of you will know how old I am by that statement)
Ok,
The truck is a 1995 X-cab 2500 with an auto. 12 Valve of course. The truck sat for 13 months prior to my friend purchasing it. The truck had guage problems, OD would not shift on/off and alot of other small things wrong.
PROBLEMS FIXED:
Got the guages repaired by tracing a broken connector inside the ignition wiring loom.
Put two new batteries in to replace the two 12 year old stock jobbers.
OD was fixed when the ignition wire was repaired and a new connector securely attached.
NOW, here is the fun part!
The Alternator was charging last night. This morning NO CHARGING.
Check Engine light is on and the code reads "charging circuit open"
The alternator was jumpered with leads directly from the battery to test the charging of the alternator itself. Not the circuit. The alternator failed. No problem, new alternator. Right!?
Wrong.
Tested the alternator and it is 100% in the green. The drop out switch tested positive when on the Modus and could be activated manually. Alternator still won't give off a charge.
NOW. I need some one who has had a similar problem with their alternator or charging system to give me a damned good reason why it isn't working.
All grounds have been cleaned and new ends placed on the truck. This dude is so anal about how clean his engine compartment is I think he is a serial killer. I don't see anything else that is obviously wrong.
Need some specific area to look at on this charging system before I commit to another weekend of flat beer and cheeto's sitting on my butt wondering what is wrong.
HELP PLEASE ! :{
Ok,
PROBLEMS FIXED:
Wrong.
HELP PLEASE ! :{
