RJOL said:Once you remove the two torque bolts, you put your fingers on the outside of the assemble (opposite the two bolts on the outside of the body), between the light assemble and the body, and carefully pry it away from two clips. The lamp assemble will pop out. Don't use a screwdriver to pry as you will chip the paint. Use your fingers! Have fun...![]()
