Originally posted by PWellwood
I just recently purschased a 30' 5th wheel that is used. The dry weight is 10,000 lbs. The tow vehicle is a 95' Dodge 3/4 ton, 2 wheel drive standard cab long bed cummins with an auto trans. and a 3. 53 rear end. I just put on a new set of michelin 245/75/16 E load tires. The hitch is rated for 15,000 lbs and I have a prodigy brake control system installed. This will be my first pull with this trailer and will be realitively flat driving. I know the data is in my owners manual but the manual for the truck is missing. Am I overloading this vehicle unsafely? Can anyone help me with this, thanks PW
P. S. wish I had at least a 4. 10 rear end.
PW, I basically have the same truck, except mine is an ext. cab & a 96'... . here are the ratings from the owners manual:
Gross Vehicle Weight Rating (GVWR) 8,800 lb
Gross Combined Weight Rating (GCWR) 16,000 lb
Payload 3,075 lb*
Max Trailer Weight 10,500 lb (hitch)
Max Trailer Weight 5th wheel application 12,500 lb
***amazing the 4:10 rearend is rated at 12,300 lb !
* The trailer weight allowance is specified for a vehicle equipped with optional trailer tow package and/or proper hitch. Payload and trailer weight allowances must be reduced by weight of passengers and non-drivetrain options.
Tongue weights: Max tongue weight 900 lbs. , must be equal to 10% of Gross Trailer Weight but no more than 15% .
**If you plan to utilize your vehicle to pull a trailer for a significant number of miles, reduce the potential for rear axle overheating by replacing rear axle lubricant with an SAE 75w140 synthetic gear lubricant. (I made this mistake, I now run Mobile1 gear lube!)
