Steve, I used Aeroquip Teflon/braided stainless steel hoses with one straight and three 90 degree SWEPT fittings to install my Amsoil Dual Remote Bypass system. The SWEPT type fittings flow quite a bit better than the hard 90 degree type fittings provided by Amsoil in the Dual Remote kit. I'm also using the trick billet aluminum block adapter as purchased from fellow TDR member "CPFF". "Willyslover" is also using the same adapter. In fact, I'm running even longer hoses than most as I have my two filters mounted more or less horizontal on the the crossmember (no room topside as my Air Bulldog intake components are in the way).
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s/DD Boost Module, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
