AMSOil Remote Bypass Filters
Warning! Laguna Speed Shop.
4" exhaust install lessons learned
Installed remote bypass filter today. Was not real easy. Had to remove right side intercooler hose, air box and tube. This unit is real quality. I mounted unit under the passenger side seat. I drilled holes thru floor and bolted to under seat floor. I do have some noise from filter. I plan some kinda rubber to help shield the noise. It will make changing the main oil filter much easier.
I mounted two Frantz Filters in the same place you did. That is an ideal mounting for remote filters. Mine are doing a great job.
I took the prsssure line from the top of the Full Flow Filter and the return directly into the oil pan.
They are doing a great job.
I mounted my remote bypass filter in the box.
I ran the Oil Return into the spare Turbo Return Oil Port, See background of the SupplyOil.jpg
I made an adaptor using the Cummins Turbo Return Oil Port Nipple, ReturnOilAdaptor.jpg
