Now I am confused, Someone posted that the new blend of Chevron Delo 400 has Molly in it, according to this Amsoil blurb below Royal Purple also has Molly in it and they state in the start of the piece that Cummins says no way to using molly in their engines.
I checked on one of my gallon jugs of Chevron Delo 400 rated "CI-4 Plus" and it says it is certified for use in Cummins engines.
This is one reason I refuse to buy and use Amsoil products, they don't make it for sale on retail shelfs and they seem to go after their rivals with reports like the one below, I wonder who this lab was and if Amsoil would reveal their name?
Or is Amsoil like the Slick 50 people who make all those claims but refuse to reveal who and how they tested.
At any rate, read what Amsoil has to say about Royal Purple and the use of Molly.
Read the Amsoil piece below:
Derek Kolb Kirkland, WA
Purchase your AMSOIL products here in the ONLINE STORE.
Find out how to get all your AMSOIL products at DEALER COST!
Royal Purple Info
As you may know, RP is big in racing circles. The chemistry they use is something we choose not to use. One of our big selling points is extended drain intervals. Some additive chemicals can cause adverse conditions when used for long periods.
Royal Purple uses a different chemistry than most. They are one of only a handful of marketers using Moly in their oil. Moly is a solid, specifically banned by Cummins, due to excessive valve train wear.
Moly (Molybdenum Disulfide) is a processed mineral that is similar in appearance to graphite. Moly has good lubricating properties when used either by itself (in dry power form or as an additive to oil or other lubricants). Particles of the Moly can come out of suspension and agglomerate. This can actually clog oil filters or oil lines and the rest normally settles in the bottom of the oil pan. This seems to be more likely when using extended drain intervals. The only test we ran on RP involved their 20W50 Racing oil versus our AMSOIL Series 2000 Synthetic 20W50 Racing Oil (TRO). We ran two 4 ball wear tests with different parameters, a spectrographic baseline, FTIR scan and volatility tests. The Royal Purple showed a significantly high volatility rate with a 12. 51% boil off rate. This compares to TRO with a 4. 47% volatility rating. Wear scars were also smaller with the TRO. For example the TRO left a . 41mm scar and the RP oil left a . 66mm scar. There was also a surprising difference in the viscosity index. The RP has a VI of 129 versus 155 for the TRO. The higher the VI, the better the viscosity stays in place at high temperatures.
This infomation was profided by AMSOIL Tech Department. They had an independent lab test Royal Purple against AMSOIL. The results are posted above. They have found Moly in Royal Purple. As stated above, this can have negitive effects on your engine.
Royal Purple Info
