"With that said this '96 I have which has been run on Delo 400 all its life looked pretty good inside at 352,000 when I pulled the head, very little cylinder wear. It did however have some soot/deposits buildup and wasn't as clean internally as an engine run on Amsoil. "
NOT to be a wiseguy, Vaughn- but how many decently serviced 325,000 mile engines using Amsoil have you seen to
base such a comparison on?
Also, On my '91 truck, my oil analysis wear metals continued to drop clear out to 100,000 miles, and IF I had switched brands or types of lubes in that period, it would have been pretty tempting to credit the new lube, instead of the natural long term seating in of the Cummins.
My new truck wear metals (Iron) dropped from about 19 ppm in the first 5000 miles to the current 3 ppm or so at 40,000 miles, and I expect it to probably drop slightly lower still up to 100,000 miles as the older '91 did. Only difference is, I've only used Delo after the first oil change at 500 miles on the latest '02...
NOW, *if* I had switched from the Delo over to a synthetic in those earlier miles, my wear metals would undoubtedly have also dropped dramatically - but could I *really* credit the synthetic for that drop, or naturally occuring breaking in and seating of engine components - which would have occured REGARDLESS of WHAT decent brand oil I used?
Guys do the dyno bit, and then post only the BEST HP numbers - drag racers do the same with their times - I fully suspect that all oil companies use various tests, and also send out MANY oil samples for analysis - which ones do ya suppose THEY select to use in their advertising?
On the other hand, oil formulations are constantly changing - today's Delo isn't the same as it was a year or so ago - the same is undoubtedly true of Amsoil and other synthetics - so analysis results could very well change too...
