More on the war
To follow up:
I don't recall exactly which Amsoil fluids I used, But I did use them throughout my truck - front end, rear-end, x-fer, transmission, engine. That is when I saw the MPG increase.
Gary - keep on speaking the truth! When I took statistics in college, the main idea was that all statistics can be "twisted" and still be valid - so can every study on oil.
Pictures of the inside of engines, 4 ball wear test, engines running with no oil at all, etc, all don't mean a thing to me anymore. I know that my rear end produced more metal flakes running amsoil than it has with Mopar or Lubrication Engineers Inc. products, and it also had the grinding problem. I know that my oil analyis showed higher levels of wear metals with amsoil than with delo - even with the amsoil bypass filter installed. I know that when I put the amsoil air filter in, the next oil sample came back with elevated silicon levels and a note to check the air induction system and change the oil immediately. I had no air problems before or since I trashed the amsoil air filter - and NO there was not a leak in the system. The air filter problem alone was enough for me to boycott amsoil.
Bottom line - do what you want, it's your truck. Take advice, consider the source - it is hard to know the source if you only see their post on a wab site. Remember, all companies say they have the best product, all test studies seem to be "independant", and nobody knows everything - and if they did, they could not put it in a post here.
Good Luck
To follow up:
Good Luck
