I've read all the posts for the Frantz filter and have picked up a lot of good information. I have a few comments and questions about the Frantz and other filters that I would like to post.
I have a physical handicap and a longer time interval between filter changes would be better for me so I think toilet paper filters are out for me. Would channelling be a problem with longer intervals using toilet paper rolls? If water is collected in the roll would longer intervals degrade the oil in the filter or is the water somehow isolated from the oil (I would have the same concern with any long interval filter). There is an explanation at
YouTube - How Water Is Removed During Bypass Filtration from
kleenoil. ca - Kleenoil Filtration System which indicates that the water is encapsulated inside the long fibres but I wonder if anyone has heard anything different.
A very similar design to the Frantz is the Jackmaster at
Oil Filters,Bypass Oil Filters,Bypass Oil Filter . It has a 15,000 km / 9300 mile filter for $10 or less and also allows the use of TP with a special fitting. The filter feeds and drains through the bottom of the housing and I was wondering if any of the captured water would drain out when the engine shuts down (if the drain is below the filter of course). There is a bolt that runs through the center of the filter but it is a smaller diameter than a TP center and there doesn't seem to a central tube for direct support of a TP core. They do have a lot of fittings and suggestions for feeding and draining the oil. One method is supplying the oil through the end of the full flow spin on filter. They also have a sandwich adapter ( also at
Oil Filter Sandwich Adapters ) that feeds oil from under the spin on filter. Has anyone had any experience with these?
Most bypass filter systems claim an increased interval for changing the full flow filter. The full flow filter is still filtering most of the oil (+95%?) and wouldn't it still get clogged up with the larger particles fairly fast - unless most large particles are formed from clumped small particles. Does anybody know what percentage of the large particles in motor oil are formed by clumping of the smaller particles?
I do a lot of small trips and have been considering the bypass filters from www(dot)Puradyn.com (
<Puradyn Oil Filtration 2010 Keep It Clean!> ) that uses a heater to evaporate water, fuel and other liquids from the oil ( also see
Hydraulic Electric Oil By-Pass Filtration System | Premo Lubrication Technologies | Tampa, FL ). These systems indicate that the water is removed by the heater (heats to about 195°F). The Puradyn uses a cotton filter and I wonder if anybody knows if any of the water would be removed by the cotton fibres. Cotton is cellulose (very long fibre?) and the wood cellulose TP removes water so why not cotton cellulose. I understand heaters are necessary to remove fuel but are they giving us a line about evaporating water? I was concerned about over heating the oil but Puradyn claims that it doesn't, it will only heat up to 195°F even with hot oil.
Purafiner (now Puradyn) has a lot of info at
Index of /files/Puradyn . There is an old file on how to calculate the filter change interval at
http://files.mainlube.com/files/Puradyn/Formula to calculate Purifiner filter change interval.pdf . Briefly it is:
960 multiplied by the filter volume (filter volume, not sump volume) divided by (engine HP divided by 100) multiplied by a safety factor (0. 5 to 0. 8 for diesel engines - gasoline engines should give more hours). The current info from Puradyn recommends changing the Puradyn filter at the car manufacturers oil change interval and changing the full flow filter every two changes. They recommend doing an oil analysis at every filter change and replace the oil when needed.
From what I've read engine hours are a more accurate method of determining oil change intervals than miles driven. I'm thinking of purchasing a meter similar to the ones at
LCD Hour Meters on ENM Company . The T54 is activated by engine vibration and doesn't need to be wired in but they have lots of other models. Anyone have experience with engine hour oil changes?
Due to the thin film evaporation chamber the Puradyn return line has to be gravity feed (1 foot drop recommended) and therefore cannot be returned to the rocker cover. The simplest return is using their fitting and punching a hole into the oil pan. They also have some banjo fittings at
http://www.puradyn.com/pdf/012808_BanjoFittingKits.pdf that replace the oil drain plug but I'm a little leary of oil change mechanics damaging the fitting or hose. Any other suggestions for a return line?
There are a couple of spin on style TP filters shown at
TRASKO-USA and
Stilko Lifetime Oil Filters - oil filter,filtration system,clean oil,oil filtering,car oil . The Trasko uses a partial roll of TP? for the bypass filter and an 8-10 micron reusable mesh filter for the overfow. The Stilko uses TP as the only filter with an overfow bypass valve without filter? for the remainder. I wonder what percentage of the oil passes through the TP and what percentage flows through the bypass valve unfiltered?
Quite a bit of this thread is really about oil quality and there are a couple of good of articles at
Car Bibles : The Engine Oil Bible and
Lincolns OnLine | Tech Tips and Articles . I've collected a lot of links pertaining to bypass filters and I'll list them at
http://eco6.com/bypass.html .
