Originally Posted by rweis
What do you think about using 2 OMRON D2VW-5L1B-1MS Long Lever, with wire leads, mounted side by side (total package width . 82") over in the area where the TV cable for us ETC folks connects?
As Karl pointed out, one switch should do the job just fine - and thanks for the pointer - I just ordered one from Mouser to use instead of the far cheaper/poorer ones mentioned earlier - those were of poor quality, with far too much slop in the actuating lever, and after digging another VERY good quality one outta my junkbox yesterday, found it was too large to install reasonably in the mounting area I plan to use.
By the way, the one I ordered from Mouser is #653-D2VW-5L2A-1MS - which is exactly like the one you supplied a number for, and was pictured, while the one your number matches is a different type than displayed, with a longer lever and NO roller tip. I figure the shorter the lever, the less potential mechanical slop and erratic actuation.
This all points up earlier comments from me about the cost of rounding up quality parts - the rotary potentiometer I figure to end up using was a $19 item - but FAR better quality than cheaper types that can be had for around $2 - or the pair if inline types that were also cheap in quality as well as price.
It can be difficult at times to obtain parts at a decent mix of price and quality, in the size and shape needed - and in single piece quantities - I located some very nice, but expensive, pots rated for 10 million operations - but only available in large quantity wholesaler lots. The one I ended up with, is a 2 million operation precision type - not quite as good, but 1/5th the price, and easily located and replaced if required.
With all that in mind, I'm focussing on installing virtually ALL the needed parts - the potentiometer and switch, as well as the filter elements, on the bellcrank side of the bracket. That allows far easier and convenient initial testing, adjustment, and eventual maintenance or replacement as needed.
