HEY - looks like we just MIGHT be on the way to eliminating the second most common of 2nd generation truck failures... Oo. Oo. Oo.
I have not had the chance to do the mesurements BUT:
The Wilson APPS ready for this:
The Wilson APPS IS AN E X A C T I mean an EXACT I mean EXACT fit to the APPS bracket.
I tried the fitment today and about fell over with excitement.
Gary sent me one of the extra brackets he had so I would not have to screw up my working DC APPS, THANKS GARY.
The Wilson APPS has a shoulder that goes into the hole in the DC APPS EXACTELY. Then I thought "well the mounting screws would not match". An EXACT match. THe APPS holes in the Wilson and the holes in the APPS bracket aligned perfectly and even the screws were the correct pitch and diameter. The screws screwed in with finger pressure.
UNBELIVEABLE!
Mike reported the APPS would start the engine but the IVS voltages are not right. Well a little voltage here and a little voltage there is workable, somehow, GARY listening?
I think we definitely have a possibility. The fitment is PERFECT virtually PERFECT.
More to come, but definitely excited!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The fitment is PERFECT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bob Weis
HMMmmmm - well, if only a SINGLE operating voltage source is needed, there are options as to voltage regulators that could be used - IF that voltage doesn't have to originate from inside the ECM. That lead is tagged as pin 31 on my ECM schematic...
THEN, the remaining question is, if the ACTUATING voltage is increased, what will the resulting increased RETURN voltage do to the ECM?![]()
You would not want to "give it a little throttle" and the APPS thinks you are requesting 2000 rpm.What I was thinking is the resistance traces are different values. Just have to measure both of them to see what they are and that should give us a direction to go.
And actually we need to get the WIlliams as close tothe OEM APPS as possible. You would not want to "give it a little throttle" and the APPS thinks you are requesting 2000 rpm. RATE of resistance will have something to do with it.
Bob Weis
Bob Weis
What will also matter is that the IVS is wired up the same way. My schematic (in the DC 2001 manual) shows the IVS as a switch with one normally closed and one normally open contact. I suspect all that electronics in the stock APPS is there to utilize a potentiometer to simulate a mechanical IVS switch with the two contacts.
On the APPS I took apart and pictured at the beginning of this thread, there is NO mechanical "switch" inside - I supect any "switching" is done instead, by a solid state sensor/switching device instead...
Perhaps that is what you mean.
Gary,
Yes, that is exactly what I was trying to say.
Your photos are good enough I could almost draw a schematic of it. I can't tell what the numbers are on some of the parts and I can't see traces underneath components to see where they go, but other than that I could probably figure it all out.
Could you check something for me on the APPS you have taken apart...
I've done a little staring at the pictures, and I think I have a good start on a schematic. In the first picture, there are two groups of six traces going off the left edge of the board. Looks like the upper group goes to the resistance elements on the other side, and the lower group goes to the connector to the ECM. Looking at the traces in the lower group from top to bottom, I think they probably go to the following connector pins: 4, 3, 5, 2, 6, 1. These would correspond to APPS ground, APPS signal, APPS +voltage, simulated IVS switch 2 (closed for not idle), simulated IVS switch 1 (closed for idle), IVS ground.
If you can confirm that the traces hook to the connector pins as I think they do, that would mean I'm on the right track and can go a bit further in drawing a schematic for it.
Karl
