After a long wait I finally got it done. A special thanks goes out to Bill and the folks at DTT for the products, but also to James Nothum for the install and hard work. As far as the transmission it got an 89, V/B, 5 Clutch update, billet hub, solenoid, and other stuff because of this! O/D clutches were burned up, blue not black, direct clutches were slipping, O/D enguagement spring was real weak and converter was slipping, I at one time thought about doing this myself, glad I changed my mind on that one. It's nice to have someone do this that knows what is going on and why it workes that way, as well as one that goes the extra mile to make sure you are happy with it, not just a customer but a partnership. The truck is different behond comparision, nothing I mean nothing is the same, I've put 13k on this stock stuff and it is all different, feel, driving, sound everything is different, not even the same truck. You don't pull those half throttle takeoffs anymore unless you know there are no cops around. I just can't get get over how it covers ground now and doesn't sound like it's winding out cause now the power is on the ground and not out of the tailpipe. Lockup is kinda a joke, If you running down the road at 70(2K) and unlock it with the switch it gains about 75 rpm, then if you jump on it, the converter will go to say 2200 unlocked at the same speed except now it gaining speed. I'm not sure I really like lockup anymore except cruising on the open road I just don't see a need in it except What that 75 (light throttle) rpm and maybe a little cooler running. It shifts firm but not jerky like going from direct to O/D with the converter locked(yea I did it in the stock stuff... . not recommended) Heck James was checking it out at 20MPH in second jammin on it breaking the tires loose, try that in stock form, I will add a different fueling curve next week but anything else will have to wait for more $. Anyone of you that is around OKC is more that welcome to come drive it so you can see the light too.
Jim
Jim
