BB,
Not Jelag here but I have put the Tekonsha 90185 Prodigy on mine as its been wonder on my other truck... It has worked so well on my Gote' and I mounted it in the dash just under the radio in the wide thin slot for storage. I drilled a hole just large enough to run the four wires from the back of the brake controller down and behind the dash to mate up with the trailer tow wiring harness. I sure looks good there and it fit snug enough that I didn't even have to mount the units case.
Might see if your local trailer place has one of these and check it out if interested...
I'm using the Prodigy now for my 30' travel trailer but I think the Hensley is a better controler. More expensive but more powerful which equates to better braking power.
http://www.hensleymfg.com/trucontrol/index.html
transit buses use a transmison retarder and not a engine brake. most buses use zf,voit and allison transmissons. the retarder system works internaly in the trans. and is controlled by the trans. computer. some fire trucks and garbage trucks use them also. as far as the lights on the enging compt. of the bus are concerned they are called deceleration lights. when there is 0 signal on the tps switch it sends a signal to a relay to put power to the lights. if you notice these lights are amber not red,as soon as the tps shows the slightest signal the decell lights go off. hope this info helps![]()
:--) Thanks for taking the time to put all this good information together. These are issues I have been wondering about.BTW my personal suggestion for a brake controller is the Brake Smart or the Jordan 20-20... . both are very adjustable and have the ability to add more braking the harder you pound on the brake pedal in a panic stop..... unlike all the rest I've seen..... except for the stock unit on the new FORDS..... the ability to feather the brake pedal for soft braking and getting 100% when you want it ""RIGHT NOW"" is very important as long as you can control it... .
