Another gauge question
Smarty Jr. help
Which intercooler?
Id like to add a transmission temp gauge to the pillar on my 05.
I have a two gauge pillar mount already.
Is there an outlet that has the complete gauge and mounting hardware?
Iv done some searching and have found pillar mounts that have to be painted.
Does any outlet sell them already in taupe?
Thanks.
The p/n for your truck for the triple gauge a-pillar mount is AM 17213. Its about $59 to $67 online at just about everywhere. Its color matched to our interiors in Taupe. Its not an exact match, but its very close.
The trans temp gauge is a pretty simple install. There is a test port on the trans that you can use for the sensor.
Go to DieselManor - Taking the Mystery out of Diesel Performance™ for complete pics of the installation and they sell everything you will need including a sender extender for installing the trans temp sensor into the test port.
Hope this helps,
Louis
Thanks for the info Louis.
Ill check them out.
I was thinking about using the accu-temp part that Geno's has instead of going to the test port.
