With all the talk about the lift pumps going out i wonder when mine will fail,just bought a new 2001 Dodge Cummins 2500 4X4. I have a 1991 6. 2 GM diesel and it has a inline pump mounted down on the frame just in front of the fuel tank. Its 10 yrs old and has 250k on it and the pump has never failed. I have seen posts where guys have changed pumps on dodges 3 times in 30K, never hear any problems on a GM 6. 2 or 6. 5 or a Ford Powerstroke. I browse the GM and Ford forums and there is very little problem, if any at all with thier pumps, i dont know if they use the same pumps, i do know they dont use the %&$#$ pump Dodge does. Has anyone put a GM or Ford pump on a Dodge, i dont know what psi or gpm they produce but they must be plenty as they run them engines with no problem. They do have a bypass from the inj. pump and they do return a lot of fuel to the tank. They are a inline pump about 4 in. long and about 2 in across. Unless i hear that somebody has tried them and they dont work on a Dodge i am going to put one on, I will leave the original pump were it is and install a GM pump by the tank.
