What settings are you using on each power adder in your stack?
Right now I've got the Smarty on Wild #9, TS MP-8 about 30 - 40%, and TST completely off. I've not really tried to dial in the optimal settings yet due to still running the stock clutch.
Yesterday, I finally ordered a SB 3850 12 CB double disc sprung hub clutch, hydraulics, fluidampr, etc. So, I plan to take off a couple days next week, install this stuff, bottom tap and stud the head, change over to Amsoil throughout, and add the MagHytech covers.
So, within a couple weeks I should be able to find a combo that works well. I may send off the TST and get the timing feature added, so I can run the Smarty with Timing Catcher, and just use TST for duration.
I think I've read others run Smarty #5, TST on 3 to 5 for daily driving and 5 to 7 for track, and TS MP-8 around 30% for daily driving and 50-70% for track. I think this will probably be a good starting point for me to play with as well, but I'm sure my limiting factor will be draining the fuel rail due to still running off the stock CP-3.
You trying to tune your new twin CP-3 twin turbo truck? --Eric
