I'd like to get in on this problem. I just put my mod in last week and towed my 18k gcwr rig to Maine and got killed on EGT's. Whole post in Need more boost thread just below this one in the outer page. I had High Tech Turbo install a bigger (60mm compared to stock 54mm) compressor wheel and housing-their stage 3 kit on my original turbo. Thought that would do the trick, but not so. Perhaps there is a leak in the system and some induction air is leaking out from a loose clamp-I'll have to check this weekend. I had to leave my TST box off b/c the injectors alone were giving too high egts uphill. Did read in the other thread that loose clamps is a possibility. Other thing is that I haven't installed boost elbow yet. High Tech made the turbo give me 28 lbs, but that's all. Putting the elbow in the weekend. I've been told that if there is nothing mechanically wrong that maybe going back to stock or at least a smaller aftermarket compressor might spool up quicker and at lower RPMs which is what we want for towing. Hopefully not necessary. Looking forward to seeing how yours turns out.
