ANOTHER transmission,TORQUE QUESTION
Strange sound under load
Smoking when cold
I have the 605 plate, and the limiting factor is largely the torque convertor clutch, and mine has it's work cut out for it, replace the tc if you want to go higher, or you may shred the whole works.
1998 2500, 12 valves, SLT, auto, 3. 54, 285/75-16, TST 230/605, t/c switch, DiPricol EGT/boost guages,K&N,camper special, 65,000 miles(2/01),
12 ton goosneck!
'01 Polaris EDGE-X 600
Mine would not even handle stock torque. When I had it replaced at DTT the third gear clutch was toasted and the T/C had visual signs of stress.
96 2500 4x4 Driftwood auto DTT TC & VB Warn 4x boards pyro,boost,trans temp on a piller, mag hytec trans pan, Reese 15k 5th wheel hitch Pulling 200 Alfa Ideal 31RL
bd had done a transmission for my truck and I have alot of power #ad
I also do alot of racing so its going to be put through it paces for sure. The only thing its missing is the "new" tc so I can transmit almost all of my power rather than most.
BD has been great in there support and are great people. Steve in the transmission shop is exellent in his knowledge of trannys and in explaining things to help me. Also before I forget Brian has more hair than it seems. #ad
96 4x4, 3. 54 posi, 6. 5"lift, 35" bfg m/t's and 35x14. 5x16. 5 boggers,dual stabalizers, aluminium wheels, sport headlights,billet grill, K/N 0880, NOS, Performance Diesel LPG, BD Pulling/Competition fuel injection pump,370hp marine injectors, ported head, Hx40 w/ 16cm2, 4" exhaust w/ 2 chamber Flomaster, BD copetition auto transmission and torque converter, Kenwood sterio System, Westach 60lb boost/ egt guage with warning light,aluminium bed rail covers,chrome diff covers, 5 foot traction bars,
475hp and 1050lb of torque on #2
530hp and 1140 with bullydog lpg maxed(only 55hp)
590hp and 1200 with lpg and nos
all done in 5th gear with 35's.
have a great day.
Adam
Raul:
My stock Dodge transmission went to
98,000 miles before a "rebuild" was
needed. I had a #6 TST plate along
with a "Trans-Go" Shift Kit. At
98,000 miles the "shuddering" started
and shortly thereafter the slippage.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
