anti bark valve
Schaeffer Lubricants??
Oil and warranty question synthetic
do some searching first.
1dslram, I didn't do much of a search for the solenoid (NOS) as I had most of these parts already. Before going out and purchasing the NOS solenoid, do some searching for other power activated solenoid that may have larger openings? I haven't tried yet, but maybe others out there would have cheaper ideas on that part of the set-up? The rest is pretty basic and cheap stuff. Maybe in the air-craft industries, hydralics & systems, auto hydralics, air systems etc. , anything that would open with power... If you were to purchase all the parts, including wire etc. not including time to weld on the couplers, I guess around $225. 00. The big ticket item is the solenoid around $185. 00. If you find something or anyone else that thinks it might work, post and we'll take a look before spending money. It needs to be some what heat resistant, can hold pressure at say 100psi etc. , etc. All the blow-off valves I have seen as are spring loaded, and open manually, or have manifold pressure assist to help open quickly... Remmember, it doesn't have to look pretty. . it's Monster Garage stuff... Once we get it perfected, we'll turn " JOHN TREIBEL" loose to CNC machine a cover for it or something cool to look at!!!
Steve:D :D
I believe I have access to solenoids that are larger than the standard NOS solenoid and at a lower price. I will be checking in the next week or so to get the parts where I can. Your idea I believe is a good one and I may be able to come up with other valves or solenoids to do the job.
Bruce
I thought that the signal coming out of the APPS was a lot different than what comes out of the TPS on the correctly valved trucks.....
I suppose since we're only looking at peak and low voltages... . and since you can program your super duper BOV for whatever throttle position (voltage) you want... . my complaint is invalid. :rolleyes:
Matt
How much more expensive would the micro-version be, and if for some twist of fate could it work in standard mode or are we stuck up S*** creek? Would we be allowed to ship it back on exchange?
Also when I checked the website, it listed the price as $675 CANADIAN and $495 US, so that sounds much better than having to spend over $600 for one.
Will
