Any 2023 issues?
Tradesman radio
V06 drag link recall
Just got home an hour ago with the new truck. First thing I did was disable the seat belt chime. The same procedure that's worked for many years still does the trick! First impression-it definitely rides better than my 3500 SRW did!
Oh yeah, especially if you got the factory air. I test drove some 1 ton Ram's before I ordered out my 22 2500. I owned an 18 2500 Laramie CTD at the time, and 1 ton's were very stiff in comparison.
You may be over the 2500's GVWR with your trailer though, depending on tongue weight/5th wheel pin weight.
Congrats on the new truck!
I’m guessing you didn’t test drive an auto-level 3500?
I factory ordered my 15 LongHorn DRW with air. First thing I noticed it was NOT the air ride system they were advertising. The manager said if I didn't like it I didn't have to keep it. On the ride home I was ready to return the truck because of the lousy ride. Checked air pressure and yep 80psi rears. Lowered to 30-35 and have been a happy customer for over 8 years now.
Just wanted to add a few other impressions from driving the truck this morning. There doesn't seem to be the slight 'lag' at take off like my 2018 had. Might be due to different torque programming. Also, the exhaust brake seems to work better to a slower speed where on the 2018, when the tach hit 1000 rpms, the exhaust brake would 'kick off'. Certainly a lot of new electronic doo dads to try to learn. The new adjustable telescoping mirrors are very nice.
Yes, I did. But there is a big difference between the 2500 and 3500 when it comes to factory air suspension. The 3500 has leaf springs and the 2500 has coils. The 3500 needs 600lbs of weight in the bed before the air suspension can do things like the Alt Ride Height. It works with an empty bed on the 2500. With a good load on it, the 3500 will ride better with the air suspension. But unloaded, it makes no difference, still rides pretty stiff.
That must not have been factory air suspension. You can't set them that way. It's controlled by the truck's computer. You can't check or set the pressure manually.
Having owned tow auto-level 3500’s I can say that stuff isn’t a good description, and pretty stiff is completely inaccurate.
The 3500 does need some weight to enter ALT, but that’s fine as the best ride occurs in normal ride height because you’re not riding on the overload springs.
There is an enormous ride difference empty between an auto-level 3500 and a standard spring 3500, to suggest there isn’t is simply laughable.
The 2500 auto-level will likely ride a little better, but the 2500 standard suspension is a stiffer ride than the 3500 auto-level.
Not IMO. I drove both types of SRW 3500's before ordering my 22 2500. But I will admit that pretty stiff is subjective. Both types of 3500's unloaded would skip over expansion strips and could get a little squirrelly in rough corners. That does not happen with my 2500's, even running 60-70psi in the tires. Note that I live in the Ozark Mts, where our roads are mostly narrow-ish and twisty. It was a pretty stark difference compared to my 18 2500 with factory air.
My point is that both ride much stiffer than a 2500 with factory air. There may be some ride difference unloaded with 3500's, but it sure was not noticeable on test rides. Don't they sit on the same leaf springs either way?
Oh, it does. Quite a bit better. But If I had towing loads that exceeded the 2500's capacities, I'd have gone 1 ton anyway.
That’s not something I’ve ever experienced, with or without auto-level, on narrow and rough roads.
I don’t have any time in a 2500 with air, but I do have some miles in a 1500 with air and even then the 3500 with air is not much stiffer than the 1500. The 3500 with air does ride better over rough roads than a standard spring 1500.
No, not even close. I figured you assumed this based on your comments.
The SRW standard spring suspension uses the same main 3/1 leaf pack that is used on the standard spring suspension DRW, but without the upper overloads. This is a fairly stiff spring pack.
The auto-level trucks have two full length leaves as the main leaves, these are fairly soft and provide a very comfortable ride empty. Very little air is kept in the bags empty at normal ride height as I only get about 3/8” drop going into bed lowering mode. This all makes for a fantastic ride on a 3500, better than any other HD truck I’ve ridden in, which is all the brands/options except the 2500 auto-level.
But, that’s not even the best part of the 3500 auto-level. Sitting below the softer main leaves are the overloads, which is one full length leaf and one half leaf on the front half. Unlike most lower overloads these are engaged with a fairly large rubber nipple that keeps contact from being abrupt as the suspension cycles in normal height. When you have sufficient payload, 500-750lbs is what is generally takes, then alternate ride height will drop the rear of the truck onto these overloads. These overloads do a great job a helping support heavy payloads and provide additional lateral stability in corners.
In bed lowering mode, no air in the bags, 2000lbs over the axle will lower the tailgate height by 2”. The main leaves lower pretty quickly onto the overloads as weight is applied, but then the rate of squat slows on the overloads. The standard springs have a rating of 2800lbs/in, which means they likely would deflect less than an inch with the same load (but I haven’t measured it in real life).
How heavy have you gotten? I’ve read more than a few accounts of the 2500 air suspension giving an overload message without being all that heavy.
If you ever did find the air suspension couldn’t keep up with your load it would be pretty easy to supplement the factory suspension with airbags. The airbags would let the OEM system do its thing without overloading, and provide additional lateral stability due to their outboard location.
