Been down this road..
Not sure if you remember how loud my truck was Ron at Mikes last fall?? I have a 4" Jardine with an extra muffler. Verlyn Fast (the 155mph truck) also had a Jardine on his.
If you like quiet, no matter who's you buy, make sure and install with band clamps. Jardine and I believe Rip use Magnflow mufflers. These have ZERO restriction.
If I was doing it all over, I would start with an off the shelf system (Jardine, Rip, Jannetty, etc). I would install with band clamps, but make sure to intall the muffler as far forward as possible. Many system (guessing) come with two 36" straight pipe pieces. When installing the muffler in the stock location, these two pieces would be installed together between the down pipe and the muffler. I would move the muffer in between these two. You need about 10" of pipe behind the down pipe to get behind the transmission hanger if you want to get as far forward as possible.
Try system, if you need queiter, I would get another 20" or 24" muffler and add it in the stock location (just cut out enough straight pipe). You will have about 24" or so pipe inbetween the two mufflers. I moved one of the factory hanger farther forward to help carry the weight. It will be quiet, you will like it.
If we ever get together again you sure welcome to drive mine!
jjw
