I set up two fans without the shrouding on my 93. With my fiver on I sit just under 16K. I made a trip up the hill on I-70 out of Denver heading west pulling the fiver. Couldn't pull the hill. Temps skyrocketed up to 250- 260. Pulled over and waited for it to cool. Made the last mile up the hill and was 250 again. I later pulled head, changed the head gasket as it was leaking. Pulled fans off. Replaced stock fan and clutch..... no problems since. I know that it would have been better if I had shrouding covering both the fans, but I was lucky to get the two on the radiator, as it was not a kit. Each fan had its own shroud and as much as I can figure covered the rad 75 to 80 percent. The fans combined cfm was rated at 5,000.
I could never figure a couple of things out...
1- I was pulling the hill at 45 mph. My simple mind thinks that at 45 there should be enough forced airflow to dissipate the heat with just the wind blowing across the radiator. If 45 is not fast enough, how fast would a guy have to go? Were the fans blocking air flow? I doubt the fans moved an equal amount of air to equal the truck moving down the road at 50 mph. So at some speed the truck was pushing the fans when they were on.
2- When the truck was sitting (running) with the AC on the fan would not keep up with the heat it was generating, and the the pop offs would blow on the pump.
3- The radiator on the first gen is small for the truck in comparison to the new trucks.
4- Even without a load, the truck itself going up a good hill like the pass over the Continental divide in Montana, would get on the hot side (230) if I had my foot in it hard.
The example of the pass out of Denver was the worst time I had.
