Just wonder if I have a problem or is this normal?
I just came back from vacation to the Black Hills and Jackson Hole. We had a great time and the temperatures were mostly in the 90's to 100+*. Seem like every time I had to go over a pass, it was 100+*.
The temperatures were up to 107* and mountain passes up to 9858 feet (Togwotte Pass, Wyoming), pulling my 7500# travel trailer plus 7600# for my truck give me a total of 15,100 total gross weight. I really got an education on EGT and water temperatures!
As most of you know, I have a ETC, 5 speed, I run a PE Comp, Bully Dog III's, PDR HX35 12 CM (Piers modified my stock turbo), BD exhaust brake, Psycotty air filter and a 4" Jardine System (stopped and taked with Jerry Jardine in Dubois, WY. He is a great guy. ) Last dyno was 422 HP and 859 ft/lbs torque.
You also may have also noticed I put on one of Calvins bumpers on the front of the White Obsession. I noticed the water temperatures had increase right after I put it on without pulling anything. I don't know if a Horton fan would help or not. Anyone have any experience with the Horton fan?
Well, back to the EGT's and water temps. Did we get hot? How about HOT! Yes we did. But of course, for any body that know me, nobody with an RV passed me going up any passes. In fact, coming back, right before going over 4th of July pass, I had another dodge with a trailer about the same size as mine kind of challenge me before the pass, I didn't do anything, I had it on cruise set at 65mph (about 71 with 285's). Before the pass on cruise, he was right behind me, I continued up the pass keeping my EGT's under 1200 pre-turbo and water temps in the operating range. I left him behind in the first mile of the pass and never saw him again.
With the Comp, I could adjust to the conditions and even at times shut it off (you can't do that with the EZ). With just the Bully Dog III's (Comp off) going up the passes I would max out at 1200* pre-turbo. Water temps at times would push the RED! However it alway seemed like I was at the top of the pass and could cool down going down the other side. (I remind you that it was 100+*) I did shut off the air conditioner at times going up the passes. While towing on the flat and boost between 6 and 10#'s, my EGT's run between 800 and 900*'s. I normally run the Comp at 3x3 while towing.
I'm think this may be a common problem for anyone who BOMBS their truck and tows. Is anyone else experiencing this?
