Anybody have a Psychotty AND a Dual Bypass kit?
Installing a PE?
wheel for 3500
I have the BMK-15 dual bypass kit mounted on the passenger side battery and i have Psychotty Intake kit (WAY overpriced piece of plastic, IMHO). Getting this setup to work required me to have to bend the large intake hose to the point where there is a slight kink in it. Does anybody have a setup like this?. Anybody know any trick to get the hose kink free?. I am not worried about it collapsing since the K&N flows so much it will never get to the starving for air point. It just does not look right, suggestions?
I have the single bypass system and a custom made Silencer ring that sticks out 3/4" out the front of the turbo. I have found what works best is to have the hose off the Psycotty end put it all the way on the turbo and slip it down on to the PSA housing. As it slides on the PSA it kind of come off the turbo slightly, I elevate it until there no kink in the hose.
Hopefully this helps.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
EMDDIESEL:
I don't have the PSA, but I do have the dual bypass. What year is your truck, and is it an auto. The reason I ask is I think I have come up with a very good place for the filter block that gets it out of the way and the filters are easy to change!
97 2500 4x4 5spd. TST/605. Exhaust Brake. Amsoil Dual Remote. Rancho 9000. Line-X. Firestone Air Bags. Kodiak Sidewinder Steps. Optima Red Tops. 30'Sunnybrooke
Sorry I don't think it will go in the same place as I put mine, because of the trans. lines.
I located mine on the right side of the engine below the turbo.
