Reb. B said:I run a 12 inch slick and its on a 16" wheel, but i have a 5/16 inch spacer and i ground down the caliple a bit. When i broke intermediate shafts and this output, its always been while staging. So as long as you have good brakes, it gonna brake regardless of what tire you have. Thanks for the good info guys. I think in the near future we will be needing billet outputs to put heavy trucks down the track faster. Only problem is finding the next weak link after the 2wd output shaft.
So, if you can’t ascertain an upgrade, then relief is just around the corner,
In December at the Orlando PRI show their’s going to be a major supplier introducing their new RH/RE 300 output shafts, a little birdie told me.
