Anybody using the "Brite Box"?
Ordered Jardine 4" - any tricks/advice for install
Web site for GPs
Thanks again to everyone who responded about the taillight flasher. I saw this other device on Genos web site and it seemed like a good idea. All the site has is a brief description and and a small picture. What they say it does is allows your regular beams to stay on when you put your brites on, therefore having twice as much lite. According to the description, it simply plugs in and wont hurt anything. Anybody use one?, is it really that easy?
This one was chewed up pretty good some time ago. You might want to read the thread at:
https://www.turbodieselregister.com/ubb//Forum3/HTML/000147.html
Oh yeah, make sure you read the whole thing if you do. It turns out that the situation is different in the later trucks.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
[This message has been edited by Joe G. (edited 05-07-2001). ]
EMDDIESEL, I have the "special" Brite-Box NOT listed in the Geno's Garage catalog (although they stock it). The "special" version allows the addition of the '99+ Sport headlights in the '94 through '98. 5 Rams (positive switched headlight systems) as a direct plug-in installation. It has worked very well for me. The only down side being the price was close to double to the "regular" Brite-Box. I know one thing, when I switch on my high beams, six of the eight PIAA Super White Platinum Series filaments change night into day. #ad
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
Yes I have one on my 2001 and I can not live with out it , I have stock bulbs and they say not to upgrade them, if you use geno's memo on how to put it in, you will have no trouble.
Cool, i have the PIAA super white bulbs but they are stock wattage. And it easy to install?, no cutting the stock wiring or anything right?
Just plug it in, turn 'em on, and enjoy mobettah brightness, not neccessarily mo headlight range. Like mine a lot.
Ron
'99 QC SLT 4X4, Forest Green, long box, camper/trailer pkg, 3. 55 axles, auto, CD/cassette, power seat, heated mirrors, HD xfer case, Two meter Radioshack ham transceiver (license KC7MME),Proud member of the vast right wing conspiracy!
'98 Arctic Cat 300 4X4 ATV
'00 Honda Recon ATV
'99 Grand Cherokee
NRA Life member
"Bible thumping" Rush Dittohead!
That is what the makers of Brite-Box said as a blanket statement however, when I asked them (directly) about using PIAA Platinum Series Super White bulbs in conjunction with the Brite-Box they said that was OK... bulb longevity would not be compromised. PIAA on the other hand, was not very receptive to the idea of having both filaments (within each bulb) driven at once. Oh well, you can't please everyone I guess.
I have had the 99+ Sport headlights/"special" Brite-Box/PIAA Platinum Series Super White 9007s and 9004s installed in my Ram for over a year now without ANY problems.
[This message has been edited by John (edited 05-09-2001). ]
Hey. . have had the bright box on my 2000 since new and had them on 2 other Rams prior to this... ... no problems at all... . easy to install and well built... and you will love the bright lights for sure
Nunya from Colorado,2000 Quad cab, auto. camper and tow package,topper, Westin Safari bar with home-made mount, PIAA`s mounted on it! Amsoil in engine and transmission with Mag-tec pan, Edelbrock IAS shocks, husky liners, FX nerf-n-steps, American racing wheels with Cooper 285`s
I got mine last Christmas and it was a little frustrating to do the install due to having to pull on the wiring to get it to the box. Also, within a week after the install, BOTH of my PIAA bulbs blew out and I replaced them with the stock ones I initially took out to install the PIAAs. Love it though, don't need the brighter bulbs anymore.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. /Mallory Fuel System and Braided Stainless Lines, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires. Dynoed at Ida's: 435 hp at the rear wheels.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Mist Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
