anything about the new quadzilla adrenaline box?
AirDog or FASS? for HP 12 valve
Looking for Air Cross Over Tube for 6BTA
I have a 01 dodge 6-speed hx 40 turbo smarty and the new qaudzilla box i have them stacked and when i take the smarty off the truck dies when the high idle starts. i was wondering if i did something wrong.
Are you running the TT??
Just a thought but, the TT is set for 3 minutes and the High Idle is 2. 5 minutes I think. If that is the case it makes sense that right after it starts to high idle that is dies??
Give me some more info like what tune you are running. . etc.
I have the aggreseve tune with the turbo timer and high idle the truck has never ran better with both boxs on but when i change the smarty to a different level that is when the truck dies. when i put it back on the level that it was on the first time its fine .
I have a similar problem and also had it with an edge comp. Ever since I unloaded smarty the truck has a short miss/stall at a random part throttle point. it only does it once per start and runs flawlessly otherwise. it never did it untill I unloaded smarty.
