Anyone try it?? What’s your opinion.
Why should one use that if there is a Cummins approved alternative available?
I say give it a shot, start with the cleaner then use the daily. I’ve had good success extending time between auto regeneration using it.Anyone try it?? What’s your opinion.
I’m in the same boat as 06 Dodge. Passive regen using archoil is much easier to achieve during my daily hwy commute to and from work, when not towing. Not sure about a bunch of short trips and soot loading, I only do that on occasion, a majority of my miles are hwy. I used the cleaner first before switching to the daily treatment. I use the regular dose, not the performance dose. MPGs are of little concern to me, my concern was the soot loading, which it has helped with. YMMV.
I’ve been thinking about trying it out but haven’t been able to find it anywhere local. Sounds like it’s been helping folks. My DPF gauge will start rising as soon as I unhook my trailer after driving 100 hwy miles and it drives me nuts. It’s almost immediately.
I haven’t seen much about the regen issue on this forum surprisingly so for those that are curious, here’s an active thread that is updated almost daily. This is where I read about it and I’m assuming the same for OP.
https://hdrams.com/forum/index.php?threads/automatic-regen-too-often.14907/
What is the Cummins approved alternative? Does the Archoil void the warranty on our trucks?Why should one use that if there is a Cummins approved alternative available?
All I know I’m not using any. DEF is $6.40 a gallon at the pump in Anchorage today
I understand that. It makes the fuel supposedly burn hotter so you use less def
DEF is used to control NOx. Nox is produced by high combustion temps and high cylinder pressure. So the hotter the ambient is, the hotter the combustion chamber is, so more DEF is required to reduce NOx. Same reason you use more DEF towing, higher load = higher combustion chamber temps, more DEF required to reduce NOx levels.In fact, I have noticed that I use more DEF when the temps are higher and when hauling which I believe it is designed that way.
