Are first gens waste gated?
Are marine 370s better?
Twin Ram intake in 1st gens?
RSchwarzli
Are any of the 1st gens waste gated or are they all non waste gated. Also what are the different turbo sizing for the 89 - 93 trucks?
Robert
The 1st gen's were not wastegated. That started with the 2nd gen's.
Both early and late model 1st gen's used a H1C turbos. The intake side and impeller are different between the nonintercooled and intercooled. The nonintercooled uses a rubber hose and clamp for the across engine connection. The intercooled models had a cast elbow that connected with band clamp. Then the elbow connected to a rubber boot that connected into the intercooler piping.
On the hot side housing there were two different ones used. One was a 21 cm and the other was a 18. 5 cm. I can't tell you exactly which one was used for which years. My 93 has a 18. 5 cm model.
Also the compressor wheel for the non I/C turbo is smaller than the I/C turbo.
I don't recall the numbers exactly, but I think its 52 mm and 56 mm.
