Not quite right, the upper ball joint is not really a ball joint but is actually a pivot joint so some up and down movement is normal and not an indication of wear, it needs to be checked for lateral movement. The lower ball joint is a real ball joint and gets checked up and down for play (up to . 009" is suposedly OK acording to Chrysler), if loose the lowers are bad.
I just checked with the local garage (not dodge) because I'm thinking mine might have finally gotten bad enough to not pass inspection... 0. 006" top and 0. 009" bottom is what they quoted me as specifications.
Mine have clunked since new and have never worn tires odd nor failed inspection... I have 180k on the clock. I'm going with Moogs from a local source...
I'm not sure why you quoted me before your reply but I want to clarify the allowable play specs. The . 006" at the upper joint is measured for lateral play and the . 009" at the lower is joint is measured for up and down play.
OK, not to hijack my own thread but does anyone have any opinions on my post # 20? Does it sound the like the ball joints are worn? Thanks all.
