What have you done with the front suspension ball joints that is a big problem.
Casey
Can you tell me what problems you have had with the ball joints?
Casey
From HBarlow 12-06-2009 02:28 PM
A similar question has already been asked regarding the new MOPAR 68RFE.
Does the Aisin six speed automatic used in cab and chassis trucks pump ATF in Park position? How about in neutral?
Reason for question is to learn how to cool ATF before shutting down after hard work such as backing trailer uphill.
Are there any plans to develop an Off-Road 2500/3500 CTD truck equipped with 37" tires, 4. 56 gears, and diff locks?
Ram engineer dudes, thanks for hanging with us tonight!
Would be great to see an air ride system from the factory. I have an aftermarket kit on my 2004 3500 and it improves the ride dramatically. Is the possibility good that we could see this?
Godspeed,
Trent
We currently do not have air ride, but we have made ride improvements for 2010MY thru mount tuning and the use of a hydromount for the cab to frame (better damping). All of the comments we have received so far has been very positive with respect to both 2500 and 3500 rides.
We've also created a short video regarding the ride improvements made for 2010MY. You can find it on our YouTube channel from the link in our signature or by clicking here: YouTube - Are you doing anything to improve the ride in this truck?
The ball joints need to be greaseable from the factory. Many of these trucks see in excess of 300,000 miles and the ball joints should last longer if they could be lubed as a regular maintenance item. No maintenance or low maintenance items are for cars and salesmen!
Godspeed,
Trent
From willde01 11-14-2009 10:29 AM
Manual regen
Would it be possible to allow the driver to force a manual regen when the dpf soot load reaches about 80% when it is convenient so the cycle could be completed. It would also be nice to allow the regen cycle to continue after you would stop the truck and turn the key off and allow the engine to continue to run until the cycle is complete then shut down the engine automatically, but allow it to be shut down in an emergency or if desired. It would also be nice if the driver could monitor the percent of dpf soot load on the overhead monitor.
